1992 GTA died while driving and won't start
Old 04-17-2008, 07:31 PM
THETONY's Avatar
Car: 1992 Trans Am GTA
Engine: 350 5.7 liter TPI
It seems to be a common problem but i can't find one similar to mine so here is the story. About 3 months ago i was driving to school and my car just shut off without warning. I had it towed home had my mechanic come over and check it out, he replaced the fuel pump and filter the car started right up and ran fine for a couple days. Then i was out cruising and the same thing happened just shut right off never to start again.
I can hear the fuel pump turn on
I swapped the pump relay and cooling fan relay both are working
when i spray starting fluid into the throttle body it will start up and obviously shut off
any help would be much appreciated
-Tony
Old 04-17-2008, 09:05 PM
saliger64504's Avatar
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
Re: 1992 GTA died while driving and won't start
are your injectors fireing? if not cheack your fuses and see if any are blown
Old 04-19-2008, 08:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Also check the resistance on your injectors.
Vintageracer
01-10-2020 05:33 PM
Brcharrelson
08-26-2015 07:47 PM
Quick Reply: 1992 GTA died while driving and won't start
