Pick up coil question and help....
Old Apr 18, 2008 | 03:29 PM
koserv's Avatar
I'm stumped on a problem. I have a 1991 TA with the 305 TPI. I'm chasing down an intermittent stumble in the higher rev's, and thought I'd replace the magnetic pick up coil. When I pulled the distributor cap, the PU coil does not match the picture in the book, and I'm at a loss as to how to track down what I need. The book shows a stock PU coil under a retainer ring that you pop off to replace the coil. The 4 "fins" that create the pulse are part of a different assembly. What I actually have is a circular copper colored ring on the outside with a 8 fin "exciter" on the inside and the actual coil on the bottom....and short of a heat wrench and a cold chisel, I can't see how to get the whole assembly off to verify what's what.
Anybody know what I might be looking at here? Aftermarket distributor? Factory go fast part? This is a R7U car, so it was intended for the track.....any help appreciated as I have a track day coming up on the 26th and need to get this solved. E-mail direct to kos@smallbytes.net.
Old Apr 18, 2008 | 10:22 PM
greencamaro's Avatar
Re: Pick up coil question and help....
Pull the distributor and knock the pin out of the drive gear, note that there may be a dimple on the gear, that should point to the rotor tip when you reasemble. Then you can pull that shaft out of the unit and get at the pickup coil.
Old Apr 19, 2008 | 05:42 PM
koserv's Avatar
Yep, that did it....thanks. Although it still did not solve my problem of missing at high revs. I'll post a new thread to see if anyone has an answer. Thanks again for the tip.....
KO
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
