need help adjusting valvez
Old Apr 21, 2008 | 09:33 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
im just putiin in a 350 and need help on how to adjsut flat tapers.we tryed ajustin them by puttim the first cyclinder on tdc and tightin the rods while it was on tdc. so we did one at a tiime every time a cyclinder went up.is there a diff way casue peope r sayin we did it worng. need help
Old Apr 21, 2008 | 10:16 PM
daghstdrummer's Avatar
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Re: need help adjusting valvez
when your adjusting the lash make sure that you tighten it so that you can still turn the pushrod between your fingers and tighten it up to just before u can't turn it without forcing it.. then the valve will be set.. then give it a 1/3 turn to "lock it in"
Old Apr 21, 2008 | 10:25 PM
Car: 86' Z28 Camaro
thata wut we did.so we did do it right. other people are sayin somthin bout doing the intake valve and exhaust valve in some kind of order idk.the book said to do it like we did.put the first cyclnder up then find the other thats up.then turn the engine till 3 is all the way up andf fint the one thats up wit that and so on....
Old Apr 21, 2008 | 11:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's nothing wrong with doing it one cylinder at time through the firing order. It just takes longer and you have no real way to tell if the lifter is on the base circle of the cam.
There are a number of ways to adjust the valves and none are the wrong way.
Some people make sure the piston is at TDC on the compression stroke and adjust the intake and the exhaust on that cylinder.
Some people watch when one rocker is fully open, they adjust the other.
I use the timing mark on the balancer. When 1 or 6 is at TDC, I adjust half the valves. Rotate the crank one full turn until 1 or 6 is at TDC then adjust the other half of the valves. If you use the forum search feature on adjusting valves, you can see the sequence I use.
All three methods work. As for how much to adjust them, as mentioned above, providing they're hydraulic lifters, adjust the rocker just enough to take the play out of the pushrod. Then adjust it 1/2 turn more and move on to the next rocker. This 1/2 turn puts the recommended .040" - .060" preload in the lifter.
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
