should i do it? 454 small block
Old Apr 21, 2008 | 10:17 PM
DirtyCanadian's Avatar
I am very tempted to buy the 454 aluminum small block for my 83 trans am, I can do this if i dont buy the quad that I want do you think it would be worth not having the quad?
Old Apr 21, 2008 | 11:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: should i do it? 454 small block
You could probably buy 2 mild BBC engines for the price of that engine. The steel block crate engine 454 SBC is worth over $12,000. A bare aluminum block is worth around $4400.
Old Apr 21, 2008 | 11:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ha! Just do a gnarly 383 stroker. Your wallet will leave you with enough money for gas, and it'll still be fast enough to kill you and 30 other people unfortunate enough to be in your wake. Fast enough to not be able to drive it on the roads at least...
Old Apr 22, 2008 | 12:12 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Let me be frank with you:
Absolutely not.
Old Apr 22, 2008 | 12:34 AM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
I would put a ls1 in first...lots of power, light, and still get over 20mpg.
Old Apr 22, 2008 | 08:40 PM
i know i bolted in a 350, but that was just to get the ball rolling and have a lil fun, personally i hate the 350, and 383's just seem like an act of desperation, I think i will buy a cheaper quad and jus go with my big block plans
Old Apr 22, 2008 | 10:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You can build a much bigger, ruder, and more powerful big block for what that 454ci SBC would run you... and then you get the joy of saying you have a big block.
For the ten large or better that the SB 454 would cost, you could build a really gnarly 496 or even just buy a 502 crate - more power, big block torque, more reliable, better sound, and money to buy gas afterwards!!
Old Apr 22, 2008 | 11:00 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Axle/Gears: 3.55
no you cant spray on the 454. the head gaskets are already too thin. then you have to run a 4.2" bore gasket. and no gasket at all. now.
Old Apr 22, 2008 | 11:13 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
I was told that I was insane when I joked about rebuilding the 472 in my 1969 Caddy and dropping it in the Firebird. A 502??? I wanna see pics of that.
Old Apr 22, 2008 | 11:35 PM
ljnowell's Avatar
wtf?
Old Apr 23, 2008 | 01:46 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
i would say buld a 421 or a 434. id stay away from the larger bore size on the 454. evan the builders tell you not to spray because of the gasket thickness between cyls.
that said you have to decide what you want.
nobody can really help you there.
the 454 sbc has a great place in a driver that wont be sprayed above a 150 shot.
Old Apr 23, 2008 | 06:38 PM
Air_Adam's Avatar
A Caddy is a whole different animal - quite a bit of fabrication to get one of those into the car, just because there is no aftermarket for those motors, or for using them in motor swaps.
The 502 Chevy though.... easy. Its outside physical dimentions are identical to the 396/427/454 big blocks, its just the bore and stroke thats different. Swapping in a 502 (or even a 540 for that matter) is no harder to install than any of the 'small' big blocks, because externally, its exactly the same.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
64goatman
Sep 9, 2015 01:09 PM
84 TA NV
Sep 6, 2015 08:02 PM
