Driveability Problems
Old Apr 24, 2008 | 03:47 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car is having some problems and I cant figure out what is causing them. The car will stall after you start it if you dont give it gas for a little bit but after that it will run better. When I drive the car, it is extremly sluggish. The T.V. Cable is misadjusted but im not sure if that it causing all of the driving problems. Also everynow and then it will have blue smoke on start up, but I cant figure out what is causing it since the motor has brand new valve seals in it. It is a 305 TPI automatic, and has a comp cams 260/260 .444.444 cam in it. What should I look into?
Old Apr 24, 2008 | 03:57 PM
dirtywhiteZ28's Avatar
Car: 84' Z28-White/T-Tops
Engine: H code LG4 305
Transmission: TH700R4
Axle/Gears: Stock 3.23
Re: Driveability Problems
Maybe a little leak down from an injector, Kinda like its flooded when you try to start it up.
Old Apr 24, 2008 | 04:26 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Mine does it too with the blue smoke but it doesn't die????
Old Apr 24, 2008 | 10:01 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Could my problem be that I need to get the computer reprogrammed because of the cam?
Old Apr 24, 2008 | 10:20 PM
I would think the tech's at comp cams would be the best ones to ask about reprogramming or not. They are usually really helpful about that kinda stuff.
Old Apr 26, 2008 | 07:28 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Any other ideas?
Old Apr 27, 2008 | 01:36 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Post full cam specs
Old Apr 27, 2008 | 04:08 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Here is a link to the cam it has in it.
http://store.summitracing.com/partde...4&autoview=sku
Old Apr 28, 2008 | 02:54 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Another thing that I noticed is that you can hear the fuel pump running (whinning) from the back of the car while the car itself is running. Is it normal for it to run that loud?
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
