quick oil psi sending unit ?
Old Apr 24, 2008 | 05:17 PM
MorrisL03's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
Howdy guys. Noticed some leakage coming from the bottom lip of the Oil pressure sending unit. the guage is pegged also so im putting 2 and 2 together and coming to the conclusion the sender is actually leaking and not something dripping onto it...then the ground. I was wondering if I needed to drain the oil etc while doing this. and can it be done with the filter on? thanks guys
Old Apr 24, 2008 | 05:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The oil pump has to be pumping in order for oil to get to that passage, other than the residual in it. In order for the pump to be pumping, the engine has to be turning.
A little will drip out, but you don't have to drain the oil or remove the filter.
Old Apr 24, 2008 | 05:39 PM
MorrisL03's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
Re: quick oil psi sending unit ?
Thanks Five! Is it a pretty simple task? 88 350 TBI. and also is it common for these things to leak?
Old Apr 24, 2008 | 09:54 PM
bgood71's Avatar
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Yup, pretty common for them to leak. Simple to replace, and no, you don't need to drain the oil.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
