weird pcv issue
Old Apr 25, 2008 | 11:49 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
weird pcv issue
hey guys
i noticed my idle was alil high and had a slight stumble when reving the engine
and is smells rich
sounded like a vacuum leak.
i already replaced my pcv valve just to not have any issues cuz the car is used and was probably over due
the store gave me soem generic one off the shelf.
now my dads buddy checked it and it seems to be always open and is always flowing extra air into the engine causing the system to think its got more air than fuel and dumps more fuel to keep the balance
i put my thumb over the pcv and it sucks right onto my skin.
with my thumb plugging the pcv my idle got better and engien sounded smoother. not by a great deal but definately noticed the difference and it went back to slight higher idle as soon as i took my thumb off
the pcv is new and rattles to tell me it works
my dads buddy says the pcv is supposed to keep opening and closing but the spring inside isnt strong enough to close the valve after the vacuum pulls it open so it stays open
so does a 305 v8 tpi need a special pcv valve or whats going on?
Old Apr 26, 2008 | 03:11 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: weird pcv issue
Its supposed to be open all the time - sort of. The only time it should be closed is when there is no vacuum, or at least not enough to open it - conditions like WOT. Parts throttle and idle it should be open. Its supposed to act as a controlled vacuum leak. Take it out and hold it in your hand. Now shake it. Does it rattle? Yes? Then its fine.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
TBRays98
Sep 6, 2015 05:05 PM
greenyone
Sep 2, 2015 03:39 PM
