What does it mean when "whiney" sounds when turning?
Old Apr 26, 2008 | 11:21 PM
tigercyberslash's Avatar
Car: 1984 Camaro Z28
Engine: V8 350 ci
Axle/Gears: Posi, Disk brakes all the way aroun
I just wanted to know what parts or common problems could possibly be wrong. I have been noticing lately that Im starting to hear a "whiney" sound when I turn the steering wheel to the left or right more so then none. I checked the power steering fluid, its full any suggestions?
I know im a lil ......
Old Apr 26, 2008 | 11:39 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Re: What does it mean when "whiney" sounds when turning?
Could be that your power steering pump is going bad.Is it getting harder to turn the steering wheel?
Old Apr 27, 2008 | 12:11 AM
WicketMike's Avatar
Car: 1989 GTA
Engine: 5.7L
maybe or hopefully you just need to add some power sterring fluid
Old Apr 27, 2008 | 01:01 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check the power steering fluid level, its probably low. Check the hoses from the PS pump to the steering box for leaks - if one of the hoses is leaking, it will probably be the return hose (the one thats just clamped on) and its pretty easy to fix.
Old May 1, 2008 | 05:40 AM
IROZINCO's Avatar
Uh, he already said the resevoir was full. So, two options, either the pump is going bad (just had to replace mine) or you have a hose binding. You can TRY some power steering sealer/conditioner, but usually, once they start making noise, they are on the way out.
Old May 1, 2008 | 05:53 AM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Make sure your belt is tight too.
Old May 1, 2008 | 01:44 PM
Engine: V8 350 ci
Well the belts are tight, the fluid is full, and it only seems o make noise after about 10-15 min of driving, the steering wheel does get a little tighter when it starts to make the noise, So looks like I should just replace the steering pump, is that right? I looked some up and there not so expensive, and looks like a bolt on-bolt off job. , ethier that or Im Am i also suppose to fill the master cylinder and the tank on the steering pump itself?
O yes and Thanks to those who took the time to read and answer my question.
Old May 1, 2008 | 04:59 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
you checked PS fluid someplace other than at the pump itself?
Old May 2, 2008 | 04:24 PM
92RS702's Avatar
Car: 92RS
Only fill the reservoir on the pump don't add power steering fluid to your master cylinder that's for your brakes.
Old May 2, 2008 | 05:05 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you'll need to get a power steering pump pulley puller to do the job.
chazman
Aug 28, 2018 03:25 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
B_Dubya
Aug 26, 2015 05:09 PM
chazman
Aug 22, 2015 02:01 PM
TheExaminer
Aug 19, 2015 10:07 PM
