Well, I think I may have severely screwed myself.
Old Apr 29, 2008 | 04:24 AM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
Due to rising gas prices I parked my half finished camaro outside and let it sit for a month. It was running when I parked it, but a month later it wouldn’t start. I now think I know why.
When I parked it, I had the flaps removed from my hood, and I had noticed water was gathering on the top of my air cleaner. Because my hood clearance sucked, and I couldn’t afford to replace my cleaner with a shorter on, I flipped the lid over, creating a bowl.
I now believe the water traveled down the air cleaner post into the carb, then through the intake manifold, in the open valves, and into the cylinders. When I wanted to drive the car again, the engine was low on oil, so I added a few quarts, and went to start it up. Wouldn’t turn over. (Dead battery and rusted cylinder walls). Three of my friends start pushing, and I tried to bump start it. The engine wouldn’t turn over, and I left large skid marks. Tried this three times before the engine finally broke loose. Got the car to start, but it was having a lack of power.
Drove it for about 50 miles, gassed up and added some HEAT. Parked it and then a week later I found froth in the oil. My question for ya’ll is what can I do to repair the damage? I assume that my entire engine has rust inside, and I want to know if I can repair the damage without pulling it all apart. Is this something that can be “Blown out the exhaust” in a manner of speaking?
Old Apr 29, 2008 | 05:19 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
Re: Well, I think I may have severely screwed myself.
in what i've seen it would be safer to rebuild and recondition that motor. if you didnt do to much damage just a cylinder hone should be ok. but if you gouged a cylinder wall your gonna have to bore it if it isnt already. look at the bright side though. this is a goo time to uprgade your rotating assembly and what not while your in there
Old Apr 29, 2008 | 08:19 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I have seen the exact same scenario cause a bent connecting rod from "hydro-lock." Your engine may be fine, it may not. You said it had a lack of power, so this would indicate may not be fine.
Old Apr 29, 2008 | 08:13 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Don't be too hasty. The water that got in the cylinder dripped into the oil pan underneath the oil. It also sat on top of the intake valves that were closed. It ran bad because the valve surfaces were rusty.
When the oil circulated it mixed up the water in the bottom of the pan.
CHANGE the oil and run it some more and see if the valves reseat and the cylinders clean up.
I don't think it's hurt that bad YET. The water in the oil is probably doing more harm now that it's in the bearings. Change the oil and give it a chance.
Running it won't make any difference if later you have to pull it down and re-ring it and resurface the valves.
If you run a tank of gas thru it and it still runs bad then pull it down.
Old Apr 30, 2008 | 09:19 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I agree with the above post.
I would also pull the plugs and squirt some lube into the cylinders and replace with new plugs.
Plugs could be rusted shut.
If it cranked and ran I doubt any damage is major.
Old May 1, 2008 | 09:55 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
I totally agree, also.
+1 on this to. I had purchased a Jet boat a few years back, that had sat for 8 years, with a built 455 olds, and all we did was took the spark plugs out, squirted some oil down all the cylinders, let it sit for a couple days, and she came loose. It ran decent, the worst thing about it, was it leaked oil, but it still ran pretty strong. If you do the proper steps, you should be just fine, I would definately change oil, and spark plugs, and run it for a while, the remaining water should just evaporate. If it seems to run pretty good again, I would change the oil after a couple hundred miles.
Old May 2, 2008 | 01:17 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
that jet boat wouldn't happen to be a 69 Tahiti would it? I've got one.
Old May 6, 2008 | 05:06 PM
STEEL's Avatar
Car: 1991 Camaro RS
Engine: LO3
She is running now, seems fine other than the terribly worn out clutch.
I lucked out
Old May 7, 2008 | 10:18 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Oh your mean, no the one with a 455 olds, was a Nordic jet boat, 76' I believe,
I had a 77' Tahiti jet with a 454 chev in it, 23 footer. loved that, but our lakes up here are drying up, so cant run them anywhare within 350 miles.
LT1Formula
Oct 8, 2015 08:34 PM
88CamZ
Oct 8, 2015 10:29 AM
HoosierinWA
Oct 7, 2015 10:15 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
