Push Rod length with Fast Burn heads?
Old Apr 29, 2008 | 02:37 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I am putting Gm Fast Burn heads on my L98 with COMP Cams 08-503-8 (CS XR276HR-12). http://store.summitracing.com/partde...8&autoview=sku This will be with 1.5 Full Roller rockers.
I am wondring if I can run stock or stock length push rods or do I need to go longer and if so how much longer?
Kevin
Old Apr 29, 2008 | 05:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Should be stock for roller lifters.
Always best to check geometry during assembly, of course.
Old Aug 1, 2010 | 07:02 PM
ch@0s's Avatar
Re: Push Rod length with Fast Burn heads?
How did it turn out? I'm putting FB heads on my L98 with a CC502 cam.
Old Aug 2, 2010 | 04:16 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Guys, stop, sell the crappy Fast-Burn heads. Why suffer a 210cc intake port, with the matching loss of flow velocity ( which is the whole point of TPI ) that can't even flow as well as a stock 170cc Vortec truck head, despite the larger valves?
even the TFS 175 heads are a better choice. You will notice a loss of low-rpm torque, and your top end power will be disappointing.
Old Aug 2, 2010 | 11:01 AM
ch@0s's Avatar
Check out this article
http://www.carcraft.com/techarticles...450/index.html
Here is my TPI
you tube video
http://www.youtube.com/watch?v=UsCCTqoYu14
soon to be replaced with this Vortec version
Reborn756
Sep 4, 2015 03:42 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
