whats wrong with my car?
Old Jul 18, 2010 | 10:00 PM
cliff1970's Avatar
Car: iroc z
i have a 1990 iroc z 305 tuneport that will sometimes crank and sometimes not. check engine light finally come on today and has a egr code. can a faulty egr valve keep a car from cranking? it runs like a top when the motor is cold but want hit a lick when its hot and sounds like its skipping very badly. ive put a new tps, icv, coolant temp sensor and a new coil. any help is greatly appreciated.
Old Jul 18, 2010 | 10:55 PM
D-Pleas's Avatar
Car: 1985 El camino
Engine: L98 350 Tuned port, stock inside
Transmission: 700r4 manual valve body, 3000 stall
Axle/Gears: 7.5 inch, moser axles, 4:11...ect
Re: whats wrong with my car?
A egr valve won't cause your engine to not crank over. That could be caused by many things. Does the starter click when it won't turn over? Check all you connections especially grounds.
Old Jul 19, 2010 | 05:53 AM
cliff1970's Avatar
Car: iroc z
the car spins over fine, just want crank or fire
Old Jul 19, 2010 | 07:03 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Your post is not clear. What's the difference between 'spinning' and 'cranking'?
Cranking is the term generally used to describe the act of the starter turning the engine before it fires and runs. If it does not crank, engine codes are meaningless.
If it cranks, but does not start and run, that's different.
Old Jul 19, 2010 | 09:34 PM
cliff1970's Avatar
Car: iroc z
it cranks, but dont start up and run. when it does finally crank which is 1 in a 100 tries, its skipping and has no power. im running out of benjamins and parts to swap
Old Jul 20, 2010 | 05:59 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
First, check for spark. Its easiest and safest to use an in line spark tester. The tester light should flash brightly. If no or intermittent flash on spark tester, check for power at the coil using a test light. Should light up on both the pink and white wires with key on. Then test between batt+ and white wire while a helper cranks engine. Light should flash. If not then you have an issue with either your ignition module or pick up coil. The pick up coil is not to be confused with the ignition coil. Pick up coil is in distributor just under the rotor.
If spark is okay, check fuel pressure, should be 40 while cranking. If pressure okay, check injector pulse. Best to use a noid light. Light should flash brightly. Check one injector on each bank. Let us know what you find with these tests.
If these items are okay, you may have a MAP, TPS, CTS or ECM issue.
Old Jul 21, 2010 | 02:18 AM
murukalo's Avatar
Car: 1988 Camaro RS
Engine: 355
Transmission: TH-350
Axle/Gears: 4:10
if you dont have a test light have a buddy come and turn the key and pull each spark plug wire one at a time put a spare plug in it and ground the plug to some bare metal, preferably away from any fuel leaks should shoot a nice bright spark out, oh and make sure you hold the boot and not the plug itself
Old Aug 2, 2010 | 11:46 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Anything new? Let us know what's happening.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
fonzie85
Exterior Parts for Sale
Oct 10, 2015 10:55 PM
dhonda200
Aug 11, 2015 11:50 PM
