1991 Z28 305 TPI WILL NOT START WILL NOT EVEN TURN OVER ANY IDEAS
Re: 1991 Z28 305 TPI WILL NOT START WILL NOT EVEN TURN OVER ANY IDEAS
Maybe it's cause your CAPSLOCK is stuck!
Quit screaming.
There's lots of things that could be going on...maybe some details of exactly what DOES happen?
Does the starter work? Is there a battery in the car? Gas?
The block could be ceased and rusted inside...who knows.
Quit screaming.
Exactly.
Check your battery connections. I've had some funky problems where the interior would light up as normal, but the engine wouldn't crank and all the dash and stuff would go dead when you tried to start the car. Tightened up the battery cables and away I went.
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Have the battery tested with a quality proffesional tester. I see many cheap batteries from wal-mart and sears fail after only a couple months, espescially if the car sits alot.
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
V.A.T.S.? i havent ever owned a fuel injected third gen, but have heard about it on here, and if it was messed up, i believe that V.A.T.S. would prevent cranking.
definietly charge/check the battery though.
battery brand new and bought complete steering column out of another camaro with key and v.a.t.s. and it did not work! any other ideas to help.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
this might be out in left field but... you need a point A to point B car....buy some rice....
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Unfortunately, I have no idea where the VATS module is or what it looks like. I just bypassed the thing entirely.
Car: 89 GTA
I don't think the vats will prevent the engine from cranking,it disables the fuel system if I am remembering correctly. If its not cranking, check the battery charge...should have at least 12volts, then start checking the starter for voltage on the signal wire with the key in the start position and the supply wire should always have bttery volts. Then work from there and don't forget to test fuses...the best way is with a test light. If you need more help PM me and I'll try to walk you through it. Good luck.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Turned out to be corrosion on the positive battery terminal and inside the positive terminal of the battery side post.
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
Start with the easy stuff first check your battery,both cables,starter,fuses and then check your vats,your car will not crank at all if it's your vats.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Check all fuses and relays, battery voltage inside and outside the battery terminals, of course check your codes.
Car: 1992 Camaro RS
Yeah VATS will result in absolutely NOTHING happening. It DOES sound like VATS to me, but the nature of that system makes ruling it out ambiguous at best.
Car: 91 z28 camaro
Engine: 305 tpi
Axle/Gears: 410 posi
not to high jack this post same car same problem...bypassed vats from the column same resistance as key nothing new starter relay in kick panel and made a bypass...nothing new battery alt, and starter. Coil and ICM were put in last summer maybe bad? car died sounded like a rock threw my exhaust thinking ICM but jumped it drove home then turned off and now will not start!!!!
