Where is the fan temp. sender?
Old May 3, 2008 | 08:23 PM
arick793's Avatar
I'm hooking all of my wires up after an engine swap, and can't figure out where the wire/ sensor are that run the fan relay. It's an 87 Camaro 305
Old May 3, 2008 | 08:33 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Where is the fan temp. sender?
theres 1 on the passenger side between the #6 and #8 plugs, one on drivers side beyween #1 and #3 plugs,later jimmy
Old May 4, 2008 | 02:00 AM
arick793's Avatar
But what wires go to them? I got rid of the ECM and the wiring harness that was attached to it.
Old May 4, 2008 | 02:33 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The passenger side is the fan temp switch, the driver's side is the temp switch for your dash gauge.
Old May 5, 2008 | 12:37 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The passenger switch directly turns on one of the fans (through a relay). It goes on pretty high though. Something like 250F The driver side one tells (told) the ECM what the temp was. The ECM controlled the other fan relay. That one was supposed to come on around 215F
Old May 5, 2008 | 11:07 PM
arick793's Avatar
How can I make the fan come on at 215 or 200? I think I found the fan relay on the drivers side... do I just run the smaller wire (I think it's green or something) to the temperature sensor?
Old May 7, 2008 | 02:00 AM
Kevin91Z's Avatar
You need to replace the fan temp turn-on switch in the passenger side head with one from a '86-'87 Buick Grand National. It bolts right in and had a turn-on temp of about 205 degrees. There are aftermarket ones that turn the fan on at 185 degrees but they are more expensive.
The only other way to turn the fan on sooner is with a manual toggle switch connected to the fan relay.
Old May 7, 2008 | 07:05 AM
mouthforcombat's Avatar
Car: '86 Iroc Z
I'm very intrigued by this (getting a grand national switch), however, didn't those come with 3.8 motors?
Old May 7, 2008 | 02:57 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Sure did, this is why we like GM. Lots of parts interchange.
Old May 7, 2008 | 08:18 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I thought the one in the front of the intake was for the fans? Not the CTS, but the other one with a fuel injector type connector, next to the CTS. If not, what's this one for?
Old May 8, 2008 | 01:27 AM
Kevin91Z's Avatar
That would be for the cold-start injector on an 85-88 TPI setup.
Old May 8, 2008 | 01:28 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Ah, so I really do have 4 temperature sensors, awesome :P
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
