Fast Burn Header/Exhaust Gasket Question...
Old May 4, 2008 | 02:53 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I am getting GM Fast Burn heads for my Camaro and was wondering what type of exhaust gasket I need to get. I know that they are D styled ports so should I go with a LT1 styled gasket? I am also keeping my Hooker Super Comps 2210 (1 /34 primaries) if that helps.
Kevin
Old May 4, 2008 | 09:13 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Fast Burn Header/Exhaust Gasket Question...
Kevin
The exhaust port should be way smaller than the pipe opening in the header. Get a gasket that is close to the pipe size of the header. While we're on the subject, burned out/leaking header gaskets are as common as dirt. Everyone gets this wrong. Here's the secret: It is not a gasket problem, it's a bolt problem.
Gaskets leak and burn out because the bolt gets loose due to temperature cycling.
The bolts that come with headers are always too short. Check the holes in the heads and get longer bolts (small headed ones). The bolt should be as long as possible to still pull the header up without the gasket and not bottom out.
You'll be suprised what the correct length turns out to be.
Loctite the threads of the bolts. Run the headers to operating temp a few times and tighten the bolts again after the gaskets seat. The loctite will accept a partial turn without loss of retention.
The threaded hole in the head is cooled by coolant and the loctite won't get hot enough to break down.
If you do this, you won't get trapped in the cycle of constantly tightening loose header bolts and changing gaskets.
And don't worry about the loctite causing the bolts to break off when you take them out. It actually prevents the metal-to-metal contact that causes the "frozen exhaust manifold bolt" syndrome.
Old May 4, 2008 | 03:10 PM
Engine: L98 350 TPI
So I assume that the LT1 styled gasket will work then?
InfernalVortex
Apr 20, 2021 11:31 AM
db057
Apr 28, 2019 07:45 AM
sreZ28
Oct 22, 2015 08:21 AM
CatmanFS
Sep 19, 2015 09:00 AM
abray1
Sep 10, 2015 04:53 PM
