weird noise at high rpm
Old May 5, 2008 | 12:28 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
im getting a weird kinda knocking or whirling noise when car is in high rpm. i was told it could possibly be a bearing inside. anybody experience this? also whats naormal oil pressure at idle and while driving? im getting very lttle or if any oil pressure at idle and may 30 cruising. that norm?
Old May 5, 2008 | 12:44 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: weird noise at high rpm
It is very possible that it is a bearing but you should be able to hear it at idle. It could be a crank bearing. I have also had a wrist pin start to go bad and it would only make noise at high rpms. Has the motor been overheated recently? I overheated mine real bad and that when I lost oil pressure and the wrist pin started making noise. It is something that isn't sever at the start but can progressively get worse. I have seen a 4.3L that had one fail and it isn't pretty. The pin failed and the rod came back up and pushed the piston through the block and fender. You'll definately have to try and listen for it at idle. If you hear nothing and it doesn't get worse in about 2 days then I would say it is the wrist pin. It could also be the rocker arms. If there loose then they will make noise. I would check that first since it is cheaper. If you have a long screw driver you can put it in different places on the motor and use it like a stethoscope to track down the location the noise is coming from. Can you describe the sound? Is it high pitched or real low? At what rpm does it start. When my wrist pin started to fail it would make noise cruising around when the motor would be running over 2000-2500rpms.
Old May 5, 2008 | 12:49 PM
Engine: 355
my dont make any noise until i hit high rpms and its about to shift it sounds like a rumbling engine when it hits that high rpms...id like to discribe but its hard to lol... im lookin at a 1969 327 engine guy says its pushing bout 300 hp. that true?
Old May 6, 2008 | 10:42 PM
Engine: 355
ok drove car today its not really a knock but in away it sounds like a chatter at high rpm... i dunno what it is
also when in drive sitting at a light my oil pressure is in the red but driving its bout 30 psi. that normal??????
Last edited by billybob6110; May 6, 2008 at 10:44 PM. Reason: Automerged Doublepost
Old May 6, 2008 | 10:47 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
what do you mean by high 5k? 7K? 12K? what? especially with a 327 and people conceived notion that they are meant to spin into the stratosphere do to the sole fact of being a 327 you could be experiencing valve float
Old May 6, 2008 | 11:33 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
I'm going to state the obvious and say that they didn't paint the guage red in a certain location for a pretty color addative to your dashboard. Red = Bad on a stock motor, no matter what it is.
theshackle
Sep 17, 2020 08:26 AM
xxx3man`
Sep 23, 2015 10:37 PM
CORV3TT3
Aug 23, 2015 11:26 AM
hokis
Aug 9, 2015 03:57 PM
