anything for rings while heads are off?
Old May 6, 2008 | 09:22 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Im switching to a comp cam and 113 heads on my 1987 305tpi is there any additive I can spray or pour on the pistons, top ring and cylinder walls while the heads are off to help break up any carbon or sticking rings? thanks.
Old May 6, 2008 | 10:22 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: anything for rings while heads are off?
Nope, none that i'd use or recommend.
Once the engine is running again, and it's idling at operating temp, pull a vacuum line and put it in a gallon jug of washer fluid. Hold the idle up to about 2500RPM and LET IT DRINK.
That'll clean out the top end nicely.
Old May 6, 2008 | 12:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are they already off? If not, do this before removal.
Although I don't recall hearing the washer fluid thing. Guess it wouldn't be a problem. Seafoam is the typical recommendation.
If the heads are already off, many, many times I've just scrapped the piston with it at TDC, and blew everything clean with compressed air and wiped down the cylinder wall after taking the piston to BDC. No issues that I'm aware of.
Old May 6, 2008 | 12:56 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
u can do what five7kid said but use a plastic scraper so u dont gouge anything...i know five7 probably figured you would know that im just throwing it in so it dont slip your mind.....
Old May 6, 2008 | 04:39 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
thanks..the heads are still on and Ive done seafoam twice in the last 8 months or so...gotta love that cloud of smoke afterwards...Is the washer fluid a joke? wouldnt that be non combustible water mostly? If not it sure would be alot cheaper than seafoam edit: just did some searching..Sonix I dont know why I doubted ya,.....seafoam $7 on your mastercard, monthly internet bill $25 on your mastercard, learning you can return the seafoam and clean your windshield and intake for $1 on thirdgen.org....priceless.
Old May 6, 2008 | 05:39 PM
five7kid's Avatar
I have never used a plastic scraper for that.
Not sure I've used a plastic scraper for anything but the windshield, actually.
Old May 6, 2008 | 05:45 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
well u dont have to its just smart to so u cant slip and gouge something....more then one way to skin a cat, just saying its a safer method....
Old May 6, 2008 | 05:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
It would take a while with a plastic scraper, and can you find one small enough? I'd use a brass or steel bristle brush.
Well heck, i'd just use the washer fluid or water. Let your engine clean itself, don't bother using elbow grease if you don't have to. Cleans itself just like a head gasket failure can
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
JHX
Aug 29, 2015 02:30 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
