Car Won't Stay Running
Old May 6, 2008 | 02:37 PM
agrassetti's Avatar
alright, so i recently posted about the car not turning over but thats fixed and now i move onto another problem... the car does not seem to want to stay on. it'll idle for a while and eventually shut down or immediately shut down as soon as i put it in gear unless i feed gas into it. I can drive it aorund the block and everything as long as im constantly hitting the gas and not letting the rpms drop.
if anyone has any idea why the hell htis is happening let me know.. i thought it would be the throttle positioning switch but i changed that and there's no difference and recently replaced to get it started were the spark plugs, distributor cap and rotor and ignition module. any suggestions would be greatly appreciated thanks
oh yeah i forgot to mention it's an 89 305 iroc tbi.
Old May 6, 2008 | 05:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Is the SES light coming on while the engine is running?
If "yes", have you checked the trouble codes?
Old May 6, 2008 | 07:32 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Car Won't Stay Running
Did you check your timing?
https://www.thirdgen.org/settingtiming
Old May 19, 2008 | 03:44 PM
bluecamarors90's Avatar
Car: 1990 camaro rs
Axle/Gears: 4.10
i have the same problem replaced fuel pump, tbi, fuel filter nothing
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
