Oil leak - please say its not the rear main, haha...
Old May 6, 2008 | 07:30 PM
threepointone's Avatar
Car: 1991 Camaro
Engine: LH0 3.1L V6
Transmission: uhh... an automatic one.
Axle/Gears: um... these ones... *points*
Ok, '91 3.1L V6 Camaro... *ahem* I've needed a transmission mount for a week or so. Yesterday on the way to work I noticed a clicking/tapping sound from the top end of the motor, as a precaution, I added a QT of oil right away and it went away... then while driving home, it started again. I stopped at autozone and let it sit then watched oil drip from somewhere between the oil pan/bell housing/transmission area. I really just need somebody to make be believe it could be more simple than the rear main seal (wishful thinking ).
Thanks in advance for even reading this.
Old May 6, 2008 | 09:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Oil leak - please say its not the rear main, haha...
On the 3.1l there are three locations that commonly leak oil. The easiest is the o-ring seal on the distributor. It sits right below the base on the housing. If you don't know it's there, you won't even notice it.
The other two locations are both what you don't want to hear. The first being the cam plate on the rear of the block. The other the rear main.
Check out the distributor first. They can leak a lot of oil.
RBob.
Old May 6, 2008 | 09:19 PM
Car: 1991 Camaro
Engine: LH0 3.1L V6
Wow, yeah- I did not know that was there. I'll definately check it out tomorrow night when I scrub down the engine to get a more accurate view. Thanks for the info!
Old May 6, 2008 | 09:32 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
There is also the oil pressure sending unit. Next to the Distributor. I am assuming the 3.1 has one just like the 305's.
Old May 6, 2008 | 09:38 PM
Car: 1991 Camaro
Engine: LH0 3.1L V6
I think I know what you're talking about, thats where I FIRST thought it was coming from. The oil pressure gauge went nuts on me yesterday too, hmm... thanks for the info!
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
