what does a zz4 cam do
Old May 6, 2008 | 11:21 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Or for that matter any cam like it.
Talking about when a camshaft has a big gap between the intake and exhaust side.
ZZ4 cam is something like .47/.51 lift and 208/210 duration.
What is a cam like that good for vs something like an lt4 hotcam where youre getting .492/.492 lift.
Whats the difference between the two and why is that the case?
Old May 6, 2008 | 11:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Makes up for the relatively poor exhaust port flow.
Old May 7, 2008 | 12:14 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: what does a zz4 cam do
The exhaust duration is a lot more than that. On the intake side it is listed as 208.
Old May 7, 2008 | 06:06 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
sorry 210 was a typo should be 220
Ya ended up having this conversation with someone else and he mentioned to make up for poor exhaust scavenging qualities of most all sbc heads.
So in what case does a cam like the LT4 hotcam become a good choice where the intake/exhaust matches
Old May 7, 2008 | 07:47 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
yes when you start upgrading the exhaust side ...ie 1.6 or bigger valves serious cleanup of the ports long tube headers 5-6 angle valve seats swirl polished under cut valves....
that is when you will start to see an improvement with a single pattern cam
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Magman
Sep 13, 2015 12:14 AM
Strick1
Sep 4, 2015 07:11 AM
