How many RPM's from a stock L98???
Old May 7, 2008 | 12:51 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
This is also a question on how accurate my stock tach is.... I know the L98 runs out of steam after 5000 RPM. I noticed lately my motor is really winding out before it shifts. My tach says like 6500 RPM when it shifts. Is this even possible? Im running a MSD 6A box, and I thought there was a rev limiter at 6k RPM. Last summer i had the TV cable adjusted so it would shift @ 5500. Now it seems like it revs a bit too high. The motor is really screaming. I got a B&M shifter and i think im in a lower gear. I bumped it into neutral today because i thought i was in 3rd.(they should make them so you can't bump them up to N)
How many RPM does it take to hurt my motor???
Old May 7, 2008 | 02:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's not the way you adjust shift point on a TH700R-4 transmission.
It is the way you burn them out. They don't like to shift when they're burnt out.
Old May 7, 2008 | 03:59 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Re: How many RPM's from a stock L98???
when whats burnt out? The cable or tranny? I adjusted the cable a few years ago to shift at peak RPM. My stock tach said it was 5500 RPM, and i didn't feel a power loss between shifts. Whats the proper way to adjust shift point?
Old May 7, 2008 | 03:03 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
IIRC, tightening the cable to make it shift later isnt as bad as having it too loose and shifting early. You can adjust it a little, but not much, or the trans will burn up.
I would double check the shift cable and make sure thats its fully getting into gear. The B&M instructions cover this well.
The stock "tach" is pretty inaccurate, its probably about a 1000 off. Mine would say 7000 even though I had a 6k rpm pill.
Pull your dipstick and smell it. You'll know if its burnt. It will smell like dog ****, wont smell anything like atf.
Old May 8, 2008 | 12:47 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Fluid smells okay. I think im getting spooked because my tach is showing high RPM. I also stripped out the whole interior because im going to redo everything. I got an exhaust cut-out with a 1" baffle where the cats used to be. I think since everything is louder, along with the inaccurate tach, im thinking its winding out too much........
Does the MSD 6A have a rev limiter at 6k RPM? It doesn't have pills like the 6AL, but i thought it had one built in.
Old May 8, 2008 | 12:59 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the MSD 6A has no rev-limiter, that is why they sell the MSD 6AL, the L means limiter. The stock TPI computer has a limiter at 10,000 rpms, so its practically useless.
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 19, 2015 10:07 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
matthew911
Aug 12, 2015 09:38 AM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
