upgrading ignition system... mallory or MSD?
Old May 8, 2008 | 02:29 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i have already called summit and learned that the summit ignition components are retagged/reboxed mallory components.
how does the summit/mallory compare to the MSD products.
the summit tech guy said that the mallory box is actually better because it is digital instead of analog and that it would operate cooler and be more accurate. the both have adjustable rev limiters and are similar as competitors get as far as specs.
which way should i go?
billit distributer $170
http://store.summitracing.com/partde...5&autoview=sku
ignition box $170
SUMMIT TOTAL $340
OR i could go MSD
MSD billet distributer $233
MSD 6AL box $220
MSD TOTAL: $453
SO... is saving $113 and going mallory/summit worth it?
beyond new plugs, and good wires, what else would i need to install either one?
Old May 9, 2008 | 09:14 AM
impaled's Avatar
Re: upgrading ignition system... mallory or MSD?
anybody???
Old May 9, 2008 | 10:18 AM
Damon's Avatar
That analog MSD stuff is starting to look pretty dated, isn't it?
MSD also has a line of newer technology digital boxes (the Digital-6 line for street applications) but they're about a $100 more than the old analog boxes.
I haven't used the Summit/Mallory stuff myself so I can't comment. I have used the Crane digital box, however, and it worked absolutely flawlessly for years under some pretty abusive conditions.
Old May 9, 2008 | 10:42 AM
mouthforcombat's Avatar
Car: '86 Iroc Z
My brother runs MSD in his 86 tpi trans am and it works very well for him.
Old May 9, 2008 | 02:17 PM
impaled's Avatar
one of the better things about the summit/mallory boxs is that it consumes less power and the output spark is significantly stronger than the msd. all of the units (mallory, summit, and msd) have a one year warranty, so thats not an issue.
here is a comparison of the summit units to the msd units (if the link works properly)
http://store.summitracing.com/compar...1&autoview=sku
i compared the mallory to the summit and all of the specs and numbers were identical, so they are definietly the same.
i would be interested in the digital msd box, but its $320 at summit, compared to the $170 for the summit/mallory and the specs are very similar.
Old May 9, 2008 | 03:03 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Old May 11, 2008 | 01:32 PM
impaled's Avatar
has anyone ran mallory?
Old May 11, 2008 | 04:57 PM
thesargster4's Avatar
Car: 1986 WS6 TransAm
Engine: THREEFIDDY!
MSD all the way. Got a complete system in my 89 iroc tpi, cant get any better in reliability.
Old Jun 8, 2008 | 08:55 AM
2E151's Avatar
Curious, whats the advantages of using an aftermarket ignition?
Old Jun 8, 2008 | 10:34 AM
ReEntry Racer's Avatar
Car: '82 TA GT1 Roadracer
Engine: ZZ4 Fast Burn 385
Transmission: TEX101A Dog Box
Axle/Gears: 3.73 4th Gen w/Auburn Racers Diff
I've used Mallory for 4 years of roadrace. The easily adjustable rev limiter and the cost were the reasons for choosing that brand. They are fine units, but I have had two failures, about 2 years apart, after I had done some welding on the car. The repair center used to be in Reno NV but has been moved. They charged me $30 to fix both failed units. I now have these as spares.
Old Jun 8, 2008 | 11:14 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I heard from friends of mine that dyno tested MSD boxes do not help unless you are running at high rpms or have a points type dizzy, I went with the pertronix HEI race dizzy w/mechanical advance and it works great even though my engine never races over 6500 RPMs.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
