how much would the parts cost to stroke your average sbc 350?
Old May 10, 2008 | 09:00 PM
DirtyCanadian's Avatar
I have a 350 that has been bored .30 over has a balanced crank, intake, carb,headers,cam, how much do you think it may cost to stroke it to a 383? just parts.
Old May 10, 2008 | 09:33 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: how much would the parts cost to stroke your average sbc 350?
okay you need a new crank...and new pistons...
Old May 10, 2008 | 11:35 PM
can the 350 be stroked to make it larger than 383?
Old May 11, 2008 | 12:33 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
i believe 40 over makes a 385? i really cant remember. it really isnt worth spending money to get the engine rebored unless the clywalls are abit damaged then i would get it redone.
you can probably get a 383 crank off ebay or something for fairly cheap.
i havnt really been looking for a cast crank, i been just searching for a forged crank and the cheapest i found so far from a well named brand was about $550. i saw somewhere tho for a crank for $250 or so bucks for a cast 383 crank. or you can get the crank from the 400 block somewhere.
Old May 12, 2008 | 09:17 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You can stroke a 350 with
3.75" stroke, and get a 383, if you also have a .030"over bore.
3.85" stroke and get a 396, if you also have a .030" over bore (I think)
4.0" stroke and get a 408, if you also have a .030" overbore.
3.75" stroke pistons are about the same price as normal 350 pistons, no biggie. The pistons to fit the 3.85" and 4.0" stroke are much more rare, less choice, and more expensive. They aren't terribly common. You need to clearance the block a lot (use hard-blok), and you need a small base circle cam and cap screw rods. It's almost better to just find a 400cid small block and skip a lot of those 'custom' hassles.
Old May 15, 2008 | 09:52 PM
i also have a 400 sbc what can I stroke that out too? i was gonna put in my TA but i didnt wanna rebuild it yet, so how much you think it would be for parts to stroke the 400 ?
Old May 15, 2008 | 11:50 PM
HawkHunter's Avatar
To do your 350 - I went with a internal balanced 383 crank so i could use my 350 harmonic balancer... If you have a 400 sbc and a 350, you'd be best off to get the 400 crank machined to the 350 mains, (around $300) replace all the main and rod bearings, if you re-use your 5.70 rods, you'd just need a set of 383 pistons and rings. You'll also need the harmonic balancer and flywheel off the 400 if you dont go with an internally balanced crank. I put some clay on my pistons and bolted on the heads to do a test revolution to make sure valves didnt hit the pistons. Do some calculations on compression ratio to select the right size pistons (dished/dome or flat-top), and i was told to watch that the rods clear the sides of the block also, although it wasnt an issue for me, one of my co-workers had to do a bit of die grinding on the block just for clearance (nothin serious though).
i dont know about the 400 stroker - sorry
Old May 15, 2008 | 11:54 PM
Johnx's Avatar
Car: 1990 Iroc
Engine: 383
Transmission: th350
Axle/Gears: 4.10
http://store.summitracing.com/egnsea...view=sku&RC=10
Jake_92RS
Jan 28, 2020 10:37 PM
htrdbmr
Aug 18, 2015 12:58 PM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
