350 Engine Question
Old May 11, 2008 | 06:32 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
350 Engine Question
Im swapping a 350 into my v6 camaro soon. The motor has no accessorie's on it or brackets. My uncle is giving me an alternator bracket off a 350 truck, i dont know the year. Will this work under my hood? Also i bought a single groove crankshaft pulley, im wanting to an alternator, power steering pump and water pump. Can i get a short enough belt that i wont need a tensioner or idler pulley?
Old May 11, 2008 | 10:06 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 350 Engine Question
you mean a long enough belt... v-belts arent made to run like a serp. set up not enough surface area to handle ps/water/alt you will need more belts plus the correct water pump as certain pump are designed for reverse rotation of a serp setup
Old May 11, 2008 | 10:28 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I dont really want to use V-belts. I was hoping to use a serpentine ( 1 belt ) system. So your saying I have to use V-belts? In that case i need to take the crankshaft pulley back to Gm Dealership and buy a 3 groove pulley? Will i need a long or short water pump? the motor is out of a 95 tahoe, so im thinking a long. The water pumps on autozone's website are all reverse water pumps.
Old May 12, 2008 | 03:12 PM
Car: 91 RS
Engine: 350 vortec
when you said single groove i was under the impression that you meant single v belt
Old May 12, 2008 | 04:18 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I meant a single groove crank pulley, sorry for the confusion.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
