CODE 13 : Oxygen sensor signal stays lean during warm engine cruise
Old May 12, 2008 | 04:19 PM
dethklok81's Avatar
Car: '88 Trans Am
Engine: 5.0 LB9 305 TPI
So i have a CODE 13 when i flash the codes...
it takes about 10-15 mins for this code to come on....
my car runs normal.. idles proper etc....
once the code comes on... my power decreases and my idling drops....
when at a stop light it'll drop to 500rpm and sometimes feels like it wants to just drop on me but "catches" and picks itself up for a few secs then goes back to 500rpm...
i have already replaced the o2 sensor...
any other suggestions?
throttle position sensor sticking?
fuel filter?
poor connection?
i'm at a lose here :/
Old Jan 11, 2014 | 04:50 PM
Madison DiCarlo's Avatar
Re: CODE 13 : Oxygen sensor signal stays lean during warm engine cruise
I am having the same problem. im glad i read this, i was just about to change my o2 sensor. i am also having serious bad gas mileage. the difference is i have a 1991 firebird v6. it has been a problem since i got the car 4 months ago but i cant seem to figure it out.
Old Jan 11, 2014 | 05:24 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Sounds like the sensor is all done. They don't last forever. I've had them go bad in 30,000 miles.
Old Jan 11, 2014 | 05:40 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Do the diagnostics from the FSM
http://www.chevythunder.com/o2_sensor_diagnostics.htm
Caspar
Jun 19, 2016 11:19 PM
stalkier
Aug 13, 2015 12:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
