Grinding noise when I start the car
Old May 13, 2008 | 08:22 AM
ACoffey's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6
Transmission: Automatic
I have a 1991 Camaro. It's had its problems in the past, but most recently i have had truoble starting it. When I turn the key, the engine makes an attempt to start, but it cant. There is a really bad grinding noise as it tries to turn over. Ive got a brand new battery, replaced the plugs, wires, cap, ari filter, fuel filter, and fuel pump prior to this problem. Any ideas?
Old May 13, 2008 | 09:35 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Re: Grinding noise when I start the car
the starter?
Old May 13, 2008 | 11:56 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
you need a new starter or your starter isn't alined properly
Old May 13, 2008 | 12:53 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Ditto, it probably needs to be shimmed properly.
B_Dubya
Aug 26, 2015 05:09 PM
hokis
Aug 9, 2015 03:57 PM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
