L69 High Output and Vapor Lock-Purchase Z28 or Not?
Old May 13, 2008 | 07:42 PM
WannaZ28's Avatar
I test drove a one owner 1983 Z28 with the HO 305 V8 L69 option and I really liked the car but I did some research here and found that they had or have a vapor lock problem. I do not want a car with problems! Should I forget this car and find another Z28 without the L69 high output 305 V8?
I read the service bulletins in the carb section that Chevy issued many years ago. They give me pause about purchaseing a L69 Camaro.
Old May 13, 2008 | 10:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: L69 High Output and Vapor Lock-Purchase Z28 or Not?
That issue applies to all the carbureted V8 3rdgens, but its really not that bad - just means it might have to crank over a couple more times (like a couple more seconds) before it starts after you shut it off hot. Its really not a big deal. It doesn't happen all the time either.
Old May 14, 2008 | 05:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
That was the case with my old LG4. It was more annoying than anything else.
JamesC
Old May 14, 2008 | 12:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I sure wouldn't consider that a sales issue on a 25yr old car
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
Stryker412
Sep 7, 2015 09:11 AM
SG91camaro
Sep 5, 2015 10:27 PM
