timing
Old May 14, 2008 | 11:06 PM
ssj2link's Avatar
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
timing
i have just completed my V8 swap and now i want to know how to time it. the problem im having is that the balancer has the timing tape on it and i dont have an indicator on the cover so i dont know where to set it at. its close cause it stays started but im sure it has to be off a little. so how do i go about doing this
Old May 15, 2008 | 12:17 AM
RK82's Avatar
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: timing
get a timing tab
Old May 15, 2008 | 12:19 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: timing
yeah go buy a mr gasket timing tab from your local parts supplier for a bout 5 bucks bolt it to the motor and get back to us....
Old May 15, 2008 | 12:28 AM
ssj2link's Avatar
Engine: 5.7/5.0
Re: timing
ah didnt think of that lol ill do it tomorrow thanks all
Old May 26, 2008 | 03:10 PM
ssj2link's Avatar
Engine: 5.7/5.0
Re: timing
okay i got the timing tab and i have another question. i tried to set the timing and im probably doing it wrong. i shot the light on the tab and try to get it near TDC but when u turn the dizzy the car shuts off and its not even close. now i didn't have the vac hoses hooked up the first time. then i plugged the one on the back then it stayed started and i drove it to put air in my tires ( lol ). now i go to try and do it again and i cant keep it started i don't have the egr hooked up cause all the little plastic hoses are cracked and busted. if i advance it far enough it will stay started. i also don't have a tach right now so i don't know what its at. if i had to guess its really high cause it sounds fast. im not sure what to do. i cant really get those hoses anywhere. my parts store doesn't have them. any advice??
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
