Which injectors should I use?
Old May 17, 2008 | 04:35 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
So I'm in the process of my 305 to 350 swap. I'm going to be reusing the tpi system and don't know which set of injectors to use. I have a set of l98 injectors from my 86 vette or the factory lb9 injectors from my 89 maro. I plan on using an AFPR with either. Both sets were functioniong properly when removed. Is there any reason I shouldn't use the l98 injectors?
Old May 17, 2008 | 05:02 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: Which injectors should I use?
Use the L98 injectors and a L98 89 prom.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
