help
Old May 19, 2008 | 04:29 PM
parkieboy's Avatar
help
does anyone know if my camaro has a shut off switch for the fuel pump on it??i HAVE A 1991 CAMARO THE RADIATOR BELT BROKE AND WON'T START SINCE
DOES ANYONE KNOW IF MY 1991 CAMARO RS HAS A SHUT OFF SWITCH ON THE FUEL PUMP.my belot broke and the car wopn/t start since then and its not the timing belt
Old May 19, 2008 | 08:41 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: help
No switch. Does the pump prime when you turn the key on?
Old May 28, 2008 | 07:53 PM
parkieboy's Avatar
Re: help
no it does not prime when i turn the key,but it does start when i put gas in the carburator
Old May 28, 2008 | 07:59 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
Re: help
what is a radiator belt??? Never knew a radiator had a belt.
Old May 28, 2008 | 10:41 PM
parkieboy's Avatar
Re: help
its actually the fan belt,sorry lost my train of thought on that one hehehe
Old May 28, 2008 | 10:43 PM
parkieboy's Avatar
Re: help
what i meant to say the fan belt,lost my train of thought on that one hehhehe
Old May 28, 2008 | 10:45 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
Re: help
Have you cleared the trouble codes from the computer? Might want to check the fuel pump fuse also.
Old May 28, 2008 | 10:50 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Axle/Gears: 3:42s
Re: help
well. you took my comment without gettin mad, thats cool. If it's not the fuel pump fuse. it might possibly be the fuel pump relay or it could be the pump took a dump. Hopefully it will be the fuse or relay. Good luck!
Old May 28, 2008 | 10:52 PM
parkieboy's Avatar
Re: help
do you that would help,clearing the trouble codes.I did check the fuse for the fuel pump but no luck
