fuel pump
Old May 24, 2008 | 08:59 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
fuel pump
how do you install the fuel pump on the side of block? i cant get mine to seat right. like its hitting sumnthin but aint nuthin in there. thanks
Old May 24, 2008 | 09:05 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: fuel pump
Is it hittin against the fuel pump rod? You have to get the arm of the fuel pump under that rod/shaft.
Old May 24, 2008 | 09:43 PM
Engine: 355
Re: fuel pump
ya i tried to put it under and it wont line up with the bottom it sticks out as its being blocked
does it gotta rest on the arm of the pump or the top off the arm basically in the space above arm?
Last edited by billybob6110; May 24, 2008 at 09:44 PM. Reason: Automerged Doublepost
Old May 24, 2008 | 10:25 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Re: fuel pump
The rod/shaft rests on the top of the fuel pump arm. It can be tricky trying to hold the shaft up and getting the arm under it. Also, double check to make sure it is the right pump for that block.
Old May 25, 2008 | 09:40 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: fuel pump
There's a 3/8" threaded hole in front of the pump pushrod. It usually has a short filler bolt in it. If you take it out and use a longer one, it will hold the pushrod up while you install the pump. Not too tight, just enough to hold it. Be sure to put the short one back or it will leak oil.
Old May 25, 2008 | 09:56 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Re: fuel pump
I prefer the method jv999 mentioned, but there is another option. Grease the rod and stick it up in its hole. The grease will hold it in place while you install the pump. Then it gets washed out when the hot oil starts flowing over it. If the rod is on the high part of the cam lobe, you can bump the starter until its on the low part of lobe. That will help to get pump seated since you won't be fighting the pump spring.
Old May 25, 2008 | 10:02 PM
Nsomnia's Avatar
Re: fuel pump
Exactly.
Old May 25, 2008 | 11:08 PM
Engine: 355
Re: fuel pump
got it in thanks guys
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
