Compression Ratio Question
Old May 24, 2008 | 11:49 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
Hey, I have a question about using a compression ratio calculator. First off some specifics on my car. As far as I know it has stock pistons with valve reliefs, 1990 L98. I replaced the heads with some built 416 heads with 58 cc combustion chambers and am using .028 head gaskets.
This is the calculator I used: http://www.campbellenterprises.com/R...o%20calculator
And these are the numbers I used:
Bore 4.00"
Stroke 3.48"
Head 58.00cc
Gasket thickness 0.028"
Deck height 0.025" (really no idea what to put here)
Valve pocket -5cc
Cylinders 8
Results:
Displacement: 349.85
Compression ration: 10.69:1
That comp. ration look about right? I didn't expect it to be quite that high.
Old May 25, 2008 | 12:28 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Compression Ratio Question
Yea I showed it as 10.6:1 as well.
-are you sure stock 1990 pistons are 5cc flat tops?
- You didn't do any work to the 416 heads at all? (why are you using them then, they aren't as good as your stock L98 heads, stock for stock...)
-no chamber work or ---hint hint--- larger valves in the 416 heads?
Old May 25, 2008 | 12:33 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
The heads were redone with bigger valves etc, but then shaved down to get back to 58cc's.
I'm not sure about the pistons all I know is that when I had the heads off they had valve reliefs.
Old May 25, 2008 | 12:43 AM
Sonix's Avatar
Car: 1982 Trans-Am
Ah, then nope, that's probably it.
How's it run? Probably pretty hot, but the knock retard is probably coming on fairly often?
Old May 25, 2008 | 11:22 AM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I don't have the car running yet, soon I hope.
Waiting on a set of pushrods from summit. Once they get here I will have just about everything to get it back together.
If you click on my cardomain link in my sig it shows what state the car is in, info on the heads is on the last page.
Old May 26, 2008 | 10:23 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The bore size of the head gasket is always larger than the cylinder bore.
4.166" typical for a 350 composite gasket.
Your online cr calc does not allow for this input for the calc so the resulting cr is a little higher.
when you account for the larger gasket bore the cr will be 10.63:1 based on your other inputs.
I use this online cr calc
http://www.wheelspin.net/calc/calc2.html
Old Jun 13, 2008 | 09:49 PM
jamez74's Avatar
Car: 1990 GTA
Engine: 350 LT1
Axle/Gears: 3.70
I'm guessing with this comp. ratio the stock starter wont cut it?
Old Jun 14, 2008 | 02:09 AM
Sonix's Avatar
Car: 1982 Trans-Am
Probably will for a little while. Mine had 10:1 and started over like a brand new car. Ran that way for a few summers, figured i'd replace it while the engine was out ( still works fine...)
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
