Is this flex plate a dual bolt pattern?
Old May 27, 2008 | 12:09 AM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
Found it in this thread and it is the same one I have. I am trying to buy a converter and need to know if this flex plate is dual bolt pattern 168 tooth.
https://www.thirdgen.org/forums/atta...eed-fra104.jpg
Old May 27, 2008 | 12:38 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: Is this flex plate a dual bolt pattern?
looks like it to me....how much is it
Old May 27, 2008 | 12:47 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
6 mounting bolts for the converter usually means it's a dual pattern. Dual pattern just means you can put a TH350 or a TH400 torque converter onto it. You can just as easily put a TH350 converter into a TH400.
Old May 27, 2008 | 12:54 AM
sweetaq's Avatar
Car: 1982 Z28
OK, wait, it is dual pattern, so does that mean when the vendor I am looking at trying to get a converter from says, "it will only fit the smaller (153 tooth) bolt pattern which is 10.5" that I can use this flex plate?
I would just go buy another flex plate but this one is already installed on my motor and came as a balanced assembly. Is this flex plate/starter it requires going to make it impossible to mount my heddman shorties?
The flex plate is 31 dollars, here is the link.
http://www.partsamerica.com/productd...tNumber=FRA104
Old May 27, 2008 | 06:27 AM
Damon's Avatar
Yes, you can. That flexplate will take both the smaller bolt pattern (typical of converters built for smaller 153 tooth flexplates) and the larger bolt pattern (typical of converters built for the larger 168 tooth flexplates).
Having a dual bolt pattern flexplate is a very handy- almost any converter will bolt up to it on one set of holes or the other.
mhatfield 14
Oct 24, 2015 07:48 AM
xxx3man`
Sep 23, 2015 10:37 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
gixxer92
Sep 1, 2015 04:32 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
