Can I block off these hoses and hole?
Old May 31, 2008 | 11:51 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Alright,
I want to know if I can remove the following hoses and just cap off where they were going to.
The highlighted areas refer to the places that I want to cap off and get rid of the hoses that go to them.
I want to plug this valve cover and remove the hose that connects to it and cap off the TB opening.
I also want to get rid of this hose that goes from this canister to the lower opening on the TB.
This would help get rid of some hoses that are strewn across my engine,
If someone could explain to me why I need to keep them that would be great, but if it's not gonna hurt anything by taking them off, then I want to get rid of them.
Will anything bad happen if I cap off the valve cover, the vacuum canister, and the throttle body openings?
Old Jun 1, 2008 | 12:45 AM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: Can I block off these hoses and hole?
hose on valve cover is not to be plugged buy a little cone air filter and stick it into valve cover never plug this.
charcaol canister up to you it is said to help with gas miliage.
Old Jun 1, 2008 | 01:13 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
If it does get plugged it wont be with a little filter, it will have a rubber grommet put in it's place.
Old Jun 1, 2008 | 01:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The one in the valve cover going to the throttle body is your PCV valve, and it provides a valuable function to remove gasses from your crankcase.
http://en.wikipedia.org/wiki/Pcv_valve
Its also deemed part of your emissions system and it cannot be tampered with on a street car in the United States.
The other one going from the evap canister (or charcoal canister) to the throttle body is what pulls gasoline vapors out of the tank. Without it, your gas tank will be under pressure while you're driving and could cause the fuel pump problems as it tries to suck gas when the tank is low. Its also considered part of the emissions devices and should not be removed.
Old Jun 1, 2008 | 06:40 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Your best bet, is to just make it look as good as possible, the valve cover. DO NOT PLUG IT, go and get a nice chrome breather cap for it, you CAN cap off the other end of it, the one on the throttle body, but do not mess with the evap canister.
gta892000
Aug 11, 2019 11:16 AM
Loudnproud86
Jul 14, 2016 12:59 AM
customblackbird
Oct 1, 2015 04:30 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
