91 TBI Distrubator with non-roller cam?
Old Jun 1, 2008 | 01:56 PM
slaman37's Avatar
Car: Current project is 70 Monte Carlo
Engine: 350 TPI (SD)
Transmission: 200-4R
Axle/Gears: 3:73, 12 bolt Limited Slip
I know it's not a 3rd gen, but I am retro fitting a 70 Monte Carlo with a TPI unit (SD).
I got a distributor from a 91 RS with a TBI. I believe that engine is a roller cam. Do I need to change the distributor gear to use my hydraulic flat tappet cam? I am going back with my Erson T-Q-20 cam... I think the specs are .449 Lift int/exh and .214 @ .050 with a 114 lobe separation.
Thanks...
Old Jun 1, 2008 | 03:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Truck TBI engines used flat tappet cams, and used the same distributor.
It'll be fine.
Old Jun 1, 2008 | 03:56 PM
slaman37's Avatar
Re: 91 TBI Distrubator with non-roller cam?
Ok, Thanks. Now I just need to get the TBI harness repinned, run the fuel lines, retro fit a late model Caprice tank with internal pump, and get the prom chip set-up. Not to mention get the body back on the frame...lol...
MustangBeater20
Oct 29, 2022 09:20 PM
junkcltr
Aug 2, 2019 11:12 PM
509 camaro fan
Sep 6, 2015 10:43 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
