I think I want a new cam? Do I?
Old Jun 1, 2008 | 08:49 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
I think I want a new camshaft... Ive heard they can add some power.
I have very little knowledge of camshaft stuff, I know how they work, thats about it. I don't know what lift amounts are good, or bad, or anything like that.
Could I get a decent camshaft that would add a little power for less that $180?
Does anything else have to be modified to put a new cam in?
A better cam will change the sound of the engine also right?
I have a 82' 305.
Could you send some links to camshafts for suggestions?
-Andrew
Old Jun 1, 2008 | 08:59 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
Re: I think I want a new cam? Do I?
your proli gunna spend about 300(comp cams .etc) and below..but flat tappet cams are cheaper than roller(you need a flat tappet)
yea..mostly the valve train..and get new valve springs to match the cam lift
yes..but it also depends on what size cam you get
http://store.summitracing.com/egnsea...115+4294887637
Old Jun 1, 2008 | 09:05 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
your gonna need a flat tappet cam, they are cheap, id save up and get some better heads at the same time. dont forget that cam is gonna need new lifters too and probably valve springs and you might as well upgrade the rockers
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
