My car starts but not everytime
Old Jun 2, 2008 | 12:00 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
ok i took my car to the shop because sometimes it wont start....not everytime but every now and then it wont start. he tells me its a butterfly switch in the ignition. Ok here's what its doing...when i put the key in and try and start it the radio,head lights and everything turns on like normal but it wont crank at all.....its just dead. no wierd sounds or anything. It still has full battery power but just wont turn the starter or anything. Could a switch in the ignition be the problem?
Old Jun 2, 2008 | 05:00 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: My car starts but not everytime
Does it click at all when you go to start?
I beleive the system is like this
key switch
starter relay
solenoid
starter
Check power at the solenoid to see what your getting. If good power, its your starter, if low or no power, check the relay, and so on.
I had the same problem in my car. I could hotwire the power to solenoid and the car would spin great. I was losing voltage somewhere between the key and starter, buuuuuut I just wired up a push button.
Old Jun 20, 2008 | 11:15 AM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
key switch
starter relay
solenoid
starter
No clicking or anything, it just wont start. I can wait for ten or fifteen minutes and it will start right up. It sounds like starter.
Old Jun 20, 2008 | 11:37 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I don't think its the starter, check the voltage at the starter and voltage at the solenoid power, while someone turns the key.
Old Jun 20, 2008 | 01:47 PM
mpb74's Avatar
Car: 1986 Iroc-Z
Engine: 355 Phase 2 Bowtie heads
Axle/Gears: 342
do you have one of those chips on your key?
Old Jun 20, 2008 | 02:01 PM
fbchica's Avatar
Car: '92 Formula 350 L98
i was having probs with my firebird for a while. it would brand new battery and alternator, but at times the thing would just be completely dead and i couldn't understand it.
turned out being a positive lead from the battery was rubbing against the power steering pulley, which rubbed through the insulation, allowing + to ground through the pulley/shaft/bearing at a slow rate as well as pissing off the ECU..
rerouted it, ziptied it to the cooling fan support spar.
Old Jun 20, 2008 | 02:26 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
My 84 T/A does this. It'll start fine 15-20 times and then I turn the key and... nothing. I've got full power to everything and if I jump it, it cranks right over. I turn the key off, then back on and it'll either start or not. If it doesn't, I turn the key off again and usually by the third start it runs fine. I've had the starter rebuilt twice and the solenoid swapped out as well. I'm at wits end trying to figure this out.
Old Jun 20, 2008 | 03:09 PM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Well on a wrecked camaro we have, the starter wouldnt start the engine up. it would just click like it was stuck. I had a buddy of mine tell me a trick to try and hit it while he started it up. well I hit it and he started it and it turned out to crank right over. 4 starts later the starter went out.maybe its an out starter
Old Jun 20, 2008 | 03:21 PM
Ozz1967's Avatar
Car: 1984 Trans Am
LOL Now that is a good example of heat-soak...haha My Camaro (long tub headers) would do that on long trips...I'd stop to get gas and then when I went to get going again...nothing. I reach down with a small hammer and hit the solenoid and bam...start right up.
Old Aug 28, 2008 | 02:16 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
took it to the shop a while back and found out it was the alarm system. They said the alarm system was killing the starter in my car so i couldn't turn it on. so thats cool.
Old Aug 28, 2008 | 03:16 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Lol, I'm surprised no one said that. Those things go bad often.
Old Aug 28, 2008 | 04:08 PM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
lol nice lmao.
Old Aug 28, 2008 | 05:00 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
lol nice lmao.
yea i've been dealing with this for i dont know how long and come to find out its the stupida$$ alarm. Sucks. But at least its fixed. I actually just diconnected my alarm a couple days ago because my keychain alarm button isn't working so everytime i would get in my car the alarm would go off and it would just stay on while im driving lol. So now i dont have an alarm.
Old Aug 28, 2008 | 09:42 PM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
What kind of alarm system do you have? I was thinking about getting this viper one installed..
Old Sep 3, 2008 | 06:17 PM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
I have no clue. Didn't take the time to look. I'm pretty sure its the stock alarm system for it...if it came with one. But half the time the alarms system didnt work anyways so it wasnt that great.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
