car almost dies after wot run
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
I finally have my stroker put together... its a carbed 383 lt1. it pulls hard as hell but if i go wot and let off the car idles down so low that my brakes no longer work properly and my oil psi drops to almst nothing then slowly comes back up. its not a big problem on the street cause i dont just let out of wot completely but at the track when i let off i dont have brakes and its a little unnerving. any ideas on what could be causing this? it also happens if i punch the throttle then try to come to a stop real quick.
Transmission: 4L80E/4L80E
You should have sufficient brake booster vacuum for one stop after vacuum is lost. If you don't, your check valve isn't holding the vacuum on the booster.
Try a vent tube tie for the other problem. I haven't done it myself, but I've been told that works.
Wait, you have an Edelbrock carb. Can't say for sure if the vent tube tie works on those.
Re: car almost dies after wot run
i had a similar problem.. when i would stop hard my car would almost die.. i was actually putting it into neutral to stop( its an automatic). my carb just needed to be tunned.. you might not be getting the best vacume.. wheres your timing at
86IROC112
Aug 17, 2015 02:00 PM
db057
Aug 11, 2015 10:11 PM
