New engine, can i get new wiring harness? anything with computer?
Old Jun 4, 2008 | 03:49 PM
wshbrn91's Avatar
Car: 1986 Z28 Camaro
Engine: Rebuilt 82' 305
Axle/Gears: Non-Posi stock =(
Hey all,
Im doing an engine swap on my 86 z28, and I have a couple questions
My old engine is the stock 86 z28 engine, 305 carbed, all stock.
The new engine is from an 82 camaro. It has no smog stuff on it or anything like that.
1. Can i get a new engine wiring harness, and how hard is it to hook up? I know how to connect to the engine, but im talking about connecting to wherever it comes from.
2. Am I going to have to do anything with the computer or anything? i have no knowledge what so ever of the computer stuff? Ive heard of burning chips and stuff? My new engine has a bigger carb with no electrical connections.
-Andrew
Old Jun 4, 2008 | 04:01 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: New engine, can i get new wiring harness? anything with computer?
you don't really need a new harness, just use the wires you need and hide the others or you could retain your factory carb and distributor. If you are using a non-cc carb make sure you run a vaccum advance dist. No need to do anything with the computer. If you go non-cc carb and dist it won't be controlling anything anyway. If you use your factory carb dist and accessories it will simply run the way it was designed.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
