What is that noise?
Old Jun 4, 2008 | 11:21 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
What is that noise?
Whenever I turn the wheel all the way around I hear a loud POP. The plastic wheel wells ar a little loose but I dont think thats whats making that noise.
Old Jun 5, 2008 | 08:18 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: What is that noise?
strut mount
Old Jun 5, 2008 | 07:05 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Is that something I should worry about? If so how much would it cost to fix it?
Old Jun 6, 2008 | 01:28 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Could be just about any front suspension part. One of mine did it alot, and I replaced the idler arm which fixed problem (about $30 IIRC). Also, the wonderbar (aka steering brace) will help alot too (about $90 IIRC). If you haven't done any of it, it's probably time for all new suspension up front anyway. Might as well save the bucks, and do it all at one time - since you have to take just about all of it apart to do any one piece.
It's amazing what new tie rod ends, ball joints, struts, shocks, idler arm, sway bar bushing & end links will do! I did mine in a day, in the driveway, replacing with Napa parts, poly bushings, Eibach springs, and Bilstein struts - about $1200 worth.
Old Jun 6, 2008 | 01:42 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
ya I guess a car with 117,000 miles will start to show its age sooner or later. I wrote down all the parts so I'll save up and do it right. Thanks alot for your help.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
