valve stem seals
Old Jun 6, 2008 | 12:02 AM
dKillaCamaro's Avatar
Car: 83 Camaro
Engine: 5.0
Axle/Gears: 3.73 open
valve stem seals
76 350
what valve stem seals should i use?
can i change these without pullin tha heads off my running longblock?
longblocks on a stand lubed up the rocker arms(valve train) a week ago now i notice one exhaust port turned wet lookin from a dry black
change them all now right
Old Jun 6, 2008 | 09:36 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: valve stem seals
Go to a parts store and ask for valve stem seals for a '78 camaro or so.
Get the fel pros. I forget the part number, it's about 7 digits long and contains about 3 sevens in it.... Seach on here if you want.
They make intake and exhaust ones, the intakes are positive seals, so you can use intakes on both if you want.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
