oil pan gasket change
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
anyone done it with the engine installed in the car? 85 iroc. how hard is it?
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: oil pan gasket change
I did it on my old car, but it definitely wasn't fun. It was on a 400 too, so maybe the shorter stroke of a 305 will make it a little easier. I did it by unbolting the motor mounts, and lifting the engine as far as it would go, with an engine hoist. Even with the engine up, it's still a really tight fit between the k-member. That, and wear some glasses. Otherwise, pieces of the old gasket, dirt, and other crap will keep falling in your eyes while you're under there.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I've done it both ways. If you get the one-piece gasket with the little clips that hold it and the pan up while you set the bolts it goes better but it's still a job. Should probably replace the rear main while you're there it's certainly leaking as well. Oh and the timing cover and balancer seal...but by the time you get to all that you've almost got the engine out...and cleaning the mating surfaces and making sure the new gaskets are set is sooo much easier on a stand.
Definitely need a lift to hold the engine up a few inches. Be sure to pull the dist before you lift it.
Transmission: 4L80E/4L80E
I didn't find it that difficult. Just removed the distributor cap, not the whole distributor.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
A 1 piece rubber one is next to impossible (I cracked mine putting it in). But a normal 4 piece one shouldn't be too bad.
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
it wasn't so bad the first time i did it, jack the motor up after removing the mounts, after everything else is out of the way. wiggle it out of there. the second time i had to do it, i just so happened to have the transmission out. and after jacking the motor up it came out without any problem. the biggest problem i've had is getting it to get past the flexplate. if its a 2-piece seal, you should replace the rear main also while you are in there, i'd really hate to have to re-do all that cause the rear main went.
Car: 1991 Camaro RS
Engine: 357cid
i didnt jack the motor up haha one piece rubber gasket with steel inserts FTW...
didnt leak but sucked... bad
I just got the 305 back in the pontiac last week after pulling it to replace all the seals. 'Course I cleaned and painted the k-member and the block before putting it back in.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I did it... Had a hell of a time too. PITA. One Piece seal and everything, I also jacked up the engine and still had troubles getting it past the flex plate.
i always see "PITA" in posts, what does it mean
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
