Pushrod question regarding proper length for application
Old Jun 6, 2008 | 06:05 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I have a ZZZ crate motor. I installed a comp 268 cam and afr 180cc heads with lunati 1.6 rockers. I went to the tighten everything down at the shop and the guys told me that I need longer pushrods for this setup. I want to know what standard hydraulic roller pushrod length is. They were recommending 7.400" rods. Any input would be greatly appreciated.
Will
Old Jun 6, 2008 | 07:59 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Pushrod question regarding proper length for application
I used to know some of the stock info off the top of my head, but it really isn't correct for what you have...sooo, just spend the 10 bucks (or make one) for an adjustable push rod absd check the pattern on the rocker...measure the adjustable PR, and order a set...depending on your cam...you might have to do one exhaust and one intake, and maybe have a set of 8 each.
Old Jun 7, 2008 | 12:19 AM
norcalz28's Avatar
Yeah I am not very familiar with this stuff, I guess I will have to do some more research. Thanks for the info
Will
Vintageracer
Jan 10, 2020 05:33 PM
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
