serpentine pullys for crank and alt.
Old Jun 7, 2008 | 12:20 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
what would the best way to go as far as converting the crank and alt pullys to serpentine? i am probably going to be going to an electrical water pump and have no a/c power steering or any smog stuff.
Old Jun 7, 2008 | 10:28 PM
rezinn's Avatar
Re: serpentine pullys for crank and alt.
You could find a wrecked late 80s GM car to salvage the mounts and accessories/pulleys. There used to be a company in florida that sold kits like this for a few hundred shipped, probably one of the best things I ever did for my camaro. With only the crank and alternator.. and probably a tensioner, I'm not sure exactly how it'd work out though.
Old Jun 8, 2008 | 05:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The v-belt alternator is different, not just the pulley. The plug on it is different too, but it can be rewired. I did it on my old car, it wasn't really hard at all. I got all of the brackets, bolts, and accessories from a junkyard car, and used that alternator as a core on a new one. Also, you will probably need an A/C delete pulley, otherwise you won't be able to use the belt tensioner. The serpentine brackets have no adjustment in them like v-belt ones do, you have to use the tensioner to get the belt tight. To be honest, if you're only going to be running an alternator, serpentine is probably overkill, a single v-belt should do the job fine.
Old Jun 8, 2008 | 11:10 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
I just replaced my crank pulley for the one in my 86 ta since it has a serpentine groove for the alt. and a v-belt groove for the ps pump. Had to also chamge the alt. pulley for the serpentine pulley I had laying around on my serpentine alt for my 88 ta and works great, I kept popping the belt on my alt with the v-belt at high rpms and the serpentine works great
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
