wil these valve springs work? link inside
Old Jun 8, 2008 | 11:07 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Im putting a xe258hr in my small block with 1.6 rockers on 113 heads. I was looking for the kit that replaces the valves and seals for .550 lift with no machining, but I cant find em. Ive done alot of reading on having the guides shaved down and getting a set of cheap z28 springs on ebay. Just want to make sure this is the correct spring for my heads, Ill be at .520 lift with the 1.6s. http://cgi.ebay.com/ebaymotors/Parts...em290236054893&
Old Jun 8, 2008 | 12:17 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: wil these valve springs work? link inside
Manley makes a spring and retainer for those heads that will allow .525 lift.
Talk to kevin91z on this board. PM him.
Old Jun 8, 2008 | 12:22 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You'll need retainers to go with those springs, too. Those springs are for stock cams, which yours just qualifies. But of course I have to recommend Manley 22410-16 and 23652-16 retainers that will get you .550" lift and last a long time.
Manley 10721-8 and 10722-8 are 1.94" - 1.50" valves with narrowed stems that will fit right in those L98 aluminum heads. The narrowed stems will give you a few more cfm in airflow. Unfortunately we dont have valve stem seals that fit.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
89mulletbird
Aug 12, 2015 07:08 PM
