good air cleaner for a carbed 350
Old Jun 9, 2008 | 03:06 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i know this is a stupid question, but what would be the best air cleaner for a weekend warrior/track car?
i have heard alot of negative things about k&n around here and i have ran that on my mustang with no issues for a long time.
so what should i go for?
here are the requirements...
*has to clear the 84 hood.
*maximum air flow
*what would be a good drop base?
*has to be able to repel water.
Old Jun 9, 2008 | 03:28 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An air cleaner that repels water????
Old Jun 9, 2008 | 03:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: good air cleaner for a carbed 350
....in case he goes mud bogging. C'mon Tim, use your imagination eh?
impaled - the 'jury' is still out as to what is better, but a common 2-3" open air cleaner (drop base) vs the stock style dual snorkle.
Snorkels give cooler air, but the open gives more (hot) air.
If you don't have a cowl hood, I don't think you need to worry about water any more then everyone else (not at all).
Old Jun 9, 2008 | 05:18 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Old oil bath air cleaner.
(oil and water do not mix)
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
