motor mount quest
Old Jun 10, 2008 | 12:03 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
motor mount quest
i just put a new 350 in my car. is there supposed to be a gap in the motor mount on the driverside? the holes linr up but i was just wondering. the passenger side sits flush so i dunno if its not right or what. im going from a 305-350 im using the 350 mounts on the block, is it just that way cause it came out of a truck? basically will it be ok like that. thanks
Old Jun 10, 2008 | 04:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There should be a gap between the engine side metal mount and the chassis side metal clamshell. The engine side front & back should rest on the metal tabs sticking out of the chassis side rubber inserts.
Old Jun 11, 2008 | 01:38 AM
Engine: 355
Re: motor mount quest
i had to use my old 305 motor mounts, the 350 ones wouldnt work.. thanks five7kid
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
