picking the correct alternator help
Old Jun 11, 2008 | 07:03 PM
Joeboy's Avatar
I have an 85 Camaro TPI 305. I think the alternator is crapping out cause the voltage will dip unless I'm on the gas. The battery has died on me a couple times, so I took it to Kragen, they ran the test and said the alternator is charging erratically and should be replaced. But they come up with like 4 different options of alternators, (varied by amperage mostly) and he couldn't recommend which one. so I need help figuring out the correct one. Any advice?
Old Jun 12, 2008 | 12:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: picking the correct alternator help
I'd just call a different parts store. Or look at that stamp on your existing alternator and match it up. That is, if you want the identical replacement one.
Is this a serp or v-belt drive?
I want to say it's a 95A version. But 1985 TPI 305 is kind of the transition time in my mind, hence why I don't even know if it's serp or v-belt.
Cornholio7979
Sep 20, 2018 02:31 AM
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Skwisgaar
Mid-West Region
Sep 1, 2015 08:41 AM
stickychinsac
Aug 31, 2015 06:06 AM
