Installed headers now I have issues
Old Jun 15, 2008 | 08:11 PM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I installed a set of hedman headers on my 82 CFI Z28 and now my idles hunts for awhile after started cold and when I am driving it, it has a good sized stumble under load off idle. If I pull out from a stop sign it will go fine for about 10 feet, stumble then take off. All of the vacuum lines are reattached except for the smog stuff since I took all that out. That port is plugged. I figured it would act funny when it went to open loop since I still need to have a o2 bung cut and welded in but it does it no matter if its in open or closed loop.
Please help me solve this.
evilstuie
Feb 28, 2016 03:33 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
