"Restore" oil additive????
Old Jun 17, 2008 | 06:05 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
http://restoreusa.com/faq.html
it claims to restore compression and make the engine run smoother. i am very sceptical of things like this, but am curious if anybody has used it?
below: a really good informative site about that talks about some additives that have been sued by the FTC for false claims and it was not mentioned.
http://www.carbibles.com/additives.html
there are a couple of people there who have used it and said it works, but i am STILL not convinced.
i am just curious if anybody has used it... ???
Old Jun 17, 2008 | 06:21 PM
Guest
Guest
Posts: n/a
Re: "Restore" oil additive????
Works for what? Making thicker oil and getting less leaks and blowby? Sure. "Restoring" your worn out engine to new? Uh, no.
Old Jun 17, 2008 | 06:55 PM
fallenleader's Avatar
Car: 1984 firebird
Engine: 2.8 v6
Axle/Gears: soon: A working car.
I got it, its blue and has grey deposits in it, if you don't shake it well enough.
Doesn't have too much viscosity so dunno, hope its not a crappy resin.
I couldn't get lucas, lucas is nice. Also running a dabble of seafoam in the oil.
downside, someone said to change it 200miles after adding the foam, gunks up the filter with crap it loosened or something.
edit: marvels mystery oil is supposed to be good, dunno what for or whats in it, its really old though.
Old Jun 17, 2008 | 07:37 PM
impaled's Avatar
exactly what i thought... i will stick to my occasional seafoam in oil. seafoam has never done me wrong.
Old Jun 17, 2008 | 08:50 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
unless your engine is smoking or has extremely low compression dont bother with that stuff
Old Jun 17, 2008 | 08:53 PM
Car: 1984 firebird
Engine: 2.8 v6
my engine is crap, didn't test compression, got to pull it out of storage. What do you think of lucas? its supposed to match any viscosity?
Edit: I won't be using restore again, seafoam YES! but going to work up for a new block. Better than trying to salvage this. in the long run...
Thanks, i'm done stealing this topic.
Hotrodboba400
Dec 10, 2019 07:07 PM
PurelyPMD
May 5, 2016 04:57 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
