Safe rpm for cam?
Old Jun 18, 2008 | 12:45 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Safe rpm for cam?
Comp xr288hr 236/242 .520/.540 not including 1.6 RR.
Comp 977 springs 441 lbs/in
383 motor, I figure peak hp is around 6k rpms. Maybe 6500 with the blower.
Figuring my trap speed at 130+ a little with TCI's calculator, puts me around 6800 rpms. At low boost levels.
4.11 gears, th350. I really need to change gears.
The motor should be good for 7500 rpms, but I'm wondering how the hydraulic lifters will take it.
Whats a safe rpm limit? I will have to adjust boost accordingly.
Old Jun 18, 2008 | 02:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You won't have any problems if you use a rev kit.
Old Jun 18, 2008 | 02:07 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Safe rpm for cam?
I don't think your valve train can handle over 6500RPM.
Old Jun 18, 2008 | 02:41 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Thats what I was looking for, I never bothered with the rev kit because peak power shouldnt be above 6500. I'm going to have to get different gears to run any kind of power.
Old Jun 18, 2008 | 03:09 PM
five7kid's Avatar
The rev kit takes a lot of load off of the valve spring. Compare the weight of a roller lifter to that of a valve - the rev kit takes all of the lifter load off of the valve spring, and therefore off of the wobbly push rod and rocker train.
Cheap insurance, even at 6500 RPMs.
Old Jun 18, 2008 | 04:18 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Yeah, good insurance no doubt, but money is tight, and I could spend the 150 bucks on lower # gears.
On the street I dont go past 6000.......usually. My valvesprings are a little stronger than the ones comp suggests. They recommended the 986.
I'm either gonna just have to run the 1/8 mile or run like 3 lbs of boost. Until I get new gears....
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Street Lethal
Apr 30, 2019 12:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
TreDeClaw
Aug 14, 2015 06:58 PM
